I shift from 4000-4200
Have they been out long enough to say they are better than floor it?
Sent from my PC36100 using Tapatalk 2
Ok well let me rephrase that. How are they doing with stock sticks??
With stroker pumps or duals. You just need to keep the rail pressure over 22,000 to keep the fuel atomization complete, if it drops below that the fuel starts to drip off the nozzle and is not properly atomized for complete combustion. Resulting in less power production from said amount of fuel...
And what kind of timing and pulse width would you run?
Looks like we can do a second CP3 for not much more then the price of a 10mm exergy. wonder what the flow comparison is between two stock ones and a 10mm or their 12mm? anybody know?
That's gonna be between you and your tuner, but if your RP is falling below 22,000 just keep backing it down untill you can hold it. Then your going to making as much power as possible from your weak cp3...
Also, I shift mine around 3800...
I did 3850 and seemed to make good power but and looked at the log and it will hold 22,500k rail pressure 3800 but egt's climbed really fast after 3200. seemed to make good power still though.
With dual pumps they work half as hard as a single modified.:thumb:
