Now with good tuning there are some trucks running around at 700hp.
For a short time...no pun intended :rofl:
I ran 711 on the custom auto pull behind dyno last summer on stock injectors and stock cp3 but its one of the higher reading dynos and was deff kind to me.
Damn, and I thought the 649 I made on that dyno was correct! :roflmao::rofl::rofl:
It may have been, was 2700Us on 20's :rofl:
I better hit 600+hp on stock injectors and cp3 or Im selling it. I better see 630-650.
How in the world are y'all getting into the 650+ range with stock sticks? What pulse width and timing are y'all runnin!?
My lb7 made 561 with a 68mm fpe on all stock parts. So the lbz better make over 600 with the twin kit.What else is done to make you think it will make that much power? Just curious because it seems like a lot.
Pat made 700+ on stock LLY injectors. prior to 4 years ago, nearly everyone was making it with stock injectors. Was it a good idea, no, but it was done over and over again
I will have 40% overs but probably not before I dyno it. I ran a 8.05 in the 1/8th with the stock charger and this setup feels like it runs much harder. With that time in a cc/lb I figured I was making over 500hp so I hope this setup makes 600+. I wont go for more hp with the 40% overs Im just doing it to help my motor live.I just don't get how a stock pump and injector combo will make much over 600. I would think you'd need one or the other modded.
You called it out earlier yourself. You said your cp3 is weak...:hello:
Either dual pump it or swap that sucker out...
Pat made 797hp on stock injectors, with PPE dual pumps on #2 only...
FYI I have ran 3300pw and anywhere from 30*-38* above 3200 rpm since 2007... I don't fear big PW
