I went against the grain and did a external balance! it was smooth as silk by a highly recommended builder.
Its no different that anyone elses results same wear, same location.
NOW, if you tell me i did it wrong then your no different then Steve!
tell me what i could do different would be appreciated though.
I asked you 2 experts this before and was IMO polite and accepting but it gets old
Dont get me wrong, i have no issue with external ballance being used, because it does work, however it is not the "best" way to ballance a crank.
External ballance correction has to travel to one on the ends of the crank to get corrected, this causes more harmonics and more torsonal twist before correction.
Internal correction only has to travel to the next clsest bobweight for correction to occur, thus lowering the correction travel time, lowering harmonics created by less torsonal twist and length traveled, and you can put what internal ballance flywheel and ballancer parts on the crank which is much lighter.
