Gorilla Girdle
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
thanks, I think that's about the first motor that I've heard of that has had a crank problem even with extra clearance in the mains
Last season one of MPL s customers with a built motor,480 over 366
I tuned his truck and ran a 2200 PW on 30 over inj, Mild tuned truckCC/SB
Broken crank:( same spot as everyone else.
He had Robs tuning at first and wanted something more custom and less HP because of his previous bad luck.
it was internal balanced with ARP main studs.
He had probaly 12000 miles on the motor
paint94979
Beer Nazi
Sep 18, 2006
11,715
it must have been your tuning :hug: :joker: that must been an awful feeling Simon
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Honestly, I would say if I thought it was tuning.
I dont see how tuning can wreck a crank though?There is only so much you can do with tuning:confused:
Trans and getiing it to run is one thing,But being hard on parts?
paint94979
Beer Nazi
Sep 18, 2006
11,715
Simon I was just giving you a hard time :D i know your tuning is just fine on hard parts :D
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I know Nick, I was just trying fig0ure out how bad tuning would effect the crank?
You can have some pretty crappy tuning and the truck will still run good times.
I know this, because i tune my own truck:D
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
Were the mains set with extra clearance?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I can tell you >40° of total timing won't bust a LLY crank at 5250 rpm and 800+ rwhp. This was a GT45 single that made peak HP at 4800.
And I can tell you that 300rwhp with <20° timing can bust an LLY crank. This was a Predator tow tune on an otherwise stock LiLLY.
So I doubt it's timing.
Lots of folk claim to have a solution for crank breakage. I can tell you I don't have a solution. Until I break a crank, I won't know anything.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
you arent comparing the same rotating assembly, one could've been manufactured differently, balanced differently, etc. therefore i don't believe that by the above test you can rule out timing...JMHO
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I've always run as much timing as the engine wanted, and that's a lot. I stage into the beams at ~30° and it goes up from there.
It might be I'm not making enough power to break a crank, dunno.
The curious thing is, the number of <500rwhp trucks that have broken cranks, and the number of 750+ trucks that haven't.
If timing was the trigger, I should snapped my first one in 2004. The Triple Stack of Doom was probably 45°+ on kill. It would actually 'burst' it had so much timing, you'd have to turn it down. People were breaking cranks back then too. The TTS Extreme had 28 deg peak, and a few broken cranks were observed back then. I don't remember anyone breaking a crank with a triple stack.
As soon as there aren't any broken cranks at <26° then I'll be a believer. So far, that's not the case.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
im not saying its a cause of failure, im just saying that by the analysis Pat posted it cant be ruled out. thats bad science. Im no scientist, but i listened in 7th grade.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Yes, it is bad science.
But not worse than, 'it must be timing' without proof that it's even related to peak cylinder pressure.
There are many theories:
A) Shock on the crankshaft. (Solid engine mounts, wheel hop, etc)
B) Timing.
C) Harmonics. (balancers, balancing, etc)
D) Factory defect.
I know "D" is some of it. Otherwise you wouldn't see stock engines or lightly tuned engines breaking cranks.
I know "A" breaks things. Anything made of hardened steel hates impact loads.
As far as "B" goes? Go to dyno and watch how gradually the power falls as you get near optimum timing. This isn't a sudden shock. It's not 'pinging' or detonating.
Harmonics? That is plausible. Dunno though.
Like I said, I don't have any answers. I just know that wild amounts of timing won't break a good factory crank. You can advance it till it bursts, and it isn't going to break the crank.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I realize that not putting something in the equation is Being ignorant.
However, there is only so much you can do with tuning.
I am curious to hear about fingers answer to this issue.?
