LB7: FPR Install Fun!!!
Krazykid
<-Daily Thought Process
Nov 22, 2008
247
Upstate, SC
Buy one from one of our vendors, and if none of them sell one, Huckstorf Diesel has them. Then contact Michael (Superdiesel) and have him mod it for you. He WILL NOT steer you wrong. :)
I was hoping to have one in hand for the R&R. What vendors here sell them?
Krazykid
Nov 22, 2008
247
Upstate, SC
Wtf
SEE Title! I have been working on getting the old FPR out and WTF!!!!!! This is a pain in the a** !!!!!!!!!!!!!!!!! I have worked my way down to be able to see and touch all three screws. Is there a way to take the FPR out with out have to take the Bridge out? I'm not sure that I know enough about what i am doing to get the bridge out. Please advise.
paint94979
Beer Nazi
Sep 18, 2006
11,715
You will have no problems pulling the bridge out. 4 bolts and 4 nuts. It will make pulling the FPR out super easy. Also make sure you have a magnet incase you let a nut or bolt fall down. Good luck
Krazykid
Nov 22, 2008
247
Upstate, SC
You should be able to pull the FPR w/o taking the bridge out. What problems are you running into?
I don't think I have the right tool to get the FPR screws out with. I have a t25 and I can put on a 1/4" socket for the top two, but how am I to get the bottom one out? Any tips would help.
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
2 inch extension and small 1/4 ratchet, its hard to see it, i try ti get the bit and extension on the bolt first and tap it to place, then put on the 1/4 ratchet, its hard to break loose in such a smal area
Krazykid
Nov 22, 2008
247
Upstate, SC
if it makes it easier on ya, dont strip the bolt unless you want to pull the cp3 :D
I'm going to do my best at Not achiving this goal!:D I have however managed to get the "easy" one out. Need to return to the harbor freight to look for some more ideas on the other two. I long t25 that I have now is to "fat" to get to the screw. The small t25 bit that I have is to short. Never have the right tool at the right time! Very frustrated. Props to all that have done this project!
Need to get this thing back together before thursday night. Any Help in SC?
1,947
You'll be fine. Just calm down and think. You're psyching yourself out, and thats self-defeating.
I used a 2" long T25 with a 1/4" socket/ratchet. Yes, it took a while, but its doable.
