Engine noise
paint94979
Beer Nazi
Sep 18, 2006
11,715
will the injector default closed/open if there is a connection issue? Truck has 57,000 miles FICM harness does not show any signs of rubbing through on the bracket
paint94979
Beer Nazi
Sep 18, 2006
11,715
also cleaned the ground to the injector and re-tightened it problem still persists
messejme
Jazzy, Me and Max
Mar 7, 2008
741
Branchburg NJ
When my harness rubbed through and started grounding out she went into a "limp mode"
The engine light came on and the injection felt like it was only occuring in half of the cylinders- felt like a toyota 4 cyl with 75 HP. This may not have any relation to your problem but I wanted to share the details of the failure.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
if it was the harness it would be in limp mode and sound different.
this isnt a harness problem. bad injector, or other internal mechanical problem.
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
did you ice pick #7 as well as #2?
i agree with ben it sounds nothing like mine did when #2 lost connection but ive heard that when #7 looses it you only loose that cylinder
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
ok, I was just wondering. if the balance rates were effed up in #5 i was thinking maybe it could be trying to compensate. but if the code is #5 that has to be #5.
