6,019
Lol im good joe
Jack honey with red bull and a miller light
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
4 bolts is 1 thing but the a/c condensor rad intercooler trans cooler? thats a lot of bs id rather not mess with,i know you guys know what your doing just trying to figure out why you did all the extra work.If its due to the lift do all the bottom work 1st then lower the truck down to the rotors or on jack stands then pull it with the front end intact
I think the time it saves getting to all the grounds , and ease of removal of TC bolts , starter wiring harness , fan, ect makes up for the time it takes to pull the stuff out ( 30 minutes maybe ) , I would never pull a dmax motor with out pulling the rad , IC , ect the extra room to work is nice IMOP .
Cool deal James glad to see she is finally under way !!
6,019
Thats for sure trent. we had the whole front clip out in an hour. Pulling it as one chunk is the only way to do it. Makes things so much easier. Keep your phone on buddy, ;)
Evan@InglewoodTrans
yerp
3,118
65
Western MA
My only question was why they removed the bumper assembly but with his setup it makes sense why they did, the rest is kinda a given you would remove it. I certainly had no issues getting access to anything in mine with the bumper on and the front wheels off.
rcr1978
790
Spring Creek, NV
I think pulling both the radiator and intercooler is a good ideah, gives you a chance to clean them really good plus makes the job easier.
James what studs are you going with A1 or ARP, I have to do my headgaskets to and was wondering what everyone likes guess I should start a new thread maybe.
6,019
Lol maybe i should put a pic of my bumper up. It sits too close to yhe core support to not be taken off and its literally a one man job to take it off in 2 min.
Im goin with arp studs for the truck. Always heard good things about them and no issues.
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
good luck on the build. looks like you guys have it all under control! The random bolt looks like the ones that hold on the reluctor wheel. I know if I ever tear my motor apart, I'll find two of them in the oil pan.
6,019
Fyi, the harbor freight 2k engin mount is very sturdy. I wouldnt hesitate to put a fully dressed motor on it. Right now mine has everything on it minus the mid plate, fly wheel, and front accesorys. Thing is very stable. I was very leary of it at first and had a hell of a time finding some 12 x 1.75 bolts that were long enough. Luckily ace hardware had some 90mm long 12.somethin grade allen bolts. I really didnt wanna hang that motor off 8.8 grade bolts
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I had the same issue finding the M12x1.75's everything was to short. I ended up finding them in the wrong bin at home depot. I bought the same stand and i'm glad I got it it was cheap and is more than up to the job. A little paint removal and greasing the hell out it really helps for spinning the motor.
custom8726
2,784
Upstate N.Y
X2, I removed all the paint on the rotating assembly and loaded it with grease;) Good luck on the build man:thumb:
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Anyone looking for those bolts i found them at fastenall and they were allens also
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Y'all remember that bolts are graded in tensile strength not shear. A 12.9 Allen will snap in half under heavy shear load with no warning compared to a 8.8 will bend alot before it breaks. Simon has a good thread on engine stand bolts somewhere around hear.
