also depends on # of passes you expect it to hold, i got 812 on stock LB7 rods.............................................................. , but only lasted 2 dyno runs and 1 - 1/4 mile pass :spit:
Thanks:thumb:
Was that with twins on fuel ?
That was a stock LB7/turbo with intake, exhaust, lift pump, "12.40" tune, modded regulator and turbo inlet....and also the reason I later rebuilt it. :rofl: (I can laugh about it now)
So would you consider this more of a tune issue or messing with the regulator that caused your motor to fail not the hp. (For instance if you had not messed with the regulator and ran that tune but had ran say a bigger turbo to get the biger power do you think it would still have broke at those power levels, I am guessing you were trying to push the stock turbo/motor on fuel only to its max?)
