I wonder if they even knew what those were.
I forget who I bought mine from so many years ago....
Yes the owner does, . merchant still stocks theirs.I wonder if they even knew what those were.
XDP still stocks them, a long with merchant automotive. Think fleece performance has a set, the Colorado have a version for them as well.Hahaha. I wonder if PPE even offer's those any more?
I think almost everyone has the big tie rod stuffI wasn't sure sense they sell the larger tie rod kits now.
Well in my case, I needed new ones any way so I just installed the larger ones. The boots had completely rotted on the inner's and outers. Same with the upper ball joints and the control arm bushings. But it was easier to buy new upper arms for $60-$70 Vs bushings and ball joints.I think almost everyone has the big tie rod stuff
I'm still thinking about this kit with aftermarket upper A-Arms. Who's A-Arms IDK well down the road. Also plan on the pitnam/idler arm braces as wellWell in my case, I needed new ones any way so I just installed the larger ones. The boots had completely rotted on the inner's and outers. Same with the upper ball joints and the control arm bushings. But it was easier to buy new upper arms for $60-$70 Vs bushings and ball joints.
The bottoms are still good for now but I did buy ball joints just in case. They are proud of the lower arms...
Went and scaled this... with the block FA4060, RA 3900 GW 7960.. without block rear axle is 2300lb puts the block at ~1600lbsFound some ballast to get the rear planted..
$50.00 for 2*2*3 Concrete blocks should be about 1500lbs, can't make it for that about and it's too cold to pour concrete right now. truck is definitely less skiddish.
Doesn't list that information in the settlement with CARB. But like PPE, they relocated over the boarder after it happened.Doesn't Russ wullenwaber own dmax store?
I try and buy local when I can.. being in Ohio I've got several 1-2 day shipping options.
For PPE, yes. North Las Vegas. Just off the 15 Freeway.North Las Vegas.
The Headquarters moved. I don't know if the moved both stores or just closed them. I just know they settled the CARB thing in 2021 like PPE and they said F-You to CA.Are you saying the one [that was] in diamond springs that was just a half hour away moved to Nevada?
