Basically how I read it. No power, no turn on.
Also no "horn relay" in the engine fuse box. The horn itself does work, but I have only one, on the DS, PS plug has a OEM block plug in it, fill that spot at a later date
Did have dealer run the vin, the xxxxx6966 part number is correct for the truck, and best they can do is $238, and have it next business day.
Getting the spare tire frame jumped the line of getting repaired parts in order of importance.. it has 18 rivets holding it in, and ties into rear spring shackle mounts. Need to get some flanged lock nuts and grade 8 bolts.
Clock spring replacement is going to wait till shocks, tie-rods and alignment get done. I think the later stuff is more important than the clock spring replacement
Picked up some 4257NA bulbs to replace the turn signal/parking lights
