Anybody try a sump in the stock fuel tank????
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Cool I was thinkin that they fit through sending unit hole for some reason. If not ED is right with cuttin the slots that would work pretty good and minimize the amount of slicing and mess.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
Do you mean like the one i run ( hellman unit) or something different ? or do you meen a actual sump pump inside the tank ?
Trent, is your sump centered on the tank or is it slightly to the side towards the body? It doesn't look centered with this pic. If you get a chance would you mind posting a few more from different angles :D
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
thats not my pic Larry, I just used as a example :rofl: , mine is centered in the tank , and is just in front of the rear tank strap .
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
Does anybody know the return rate from the Fass to the tank, we're tinkering with the idea of using a drawstraw to the bottom of the tank for the return rather than the filler neck :D
TrentNell
Jul 7, 2008
7,543
slc tuah
could help with the foaming ? , i have never worried bout it though :D
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
depends on the return rate pressure I would think, although looking how the filler neck is just shooting fuel in from the top :thinking2: using a big hole, returning the fuel with a 1/2 inch drawstraw might increase velocity.......good thing I have a new tank with no crud in it to experiment with :D
$Smokin_Duradog$
Sep 16, 2006
209
Goshen, IN
I talked to the guys from Airdog at RPM Fest in LaPorte Indiana and they have come out with a revised system that has a sump type pick with a trap door to keep fuel in the basket when it sloshs away. We have installed their units on a few trucks and the straw setup is terrible :( Not sure if the info will help but thought I would throw it out there :)
9,906
152
Good info - thanks. I will be keeping my eyes open for this.
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
68Skylark did most of the install, I just helped "a little" :D the hellman is mounted sorta inthe middle of the tank towards the driver side more so, the drawstraw return is on the flat part on the top of the tank.
