LLY: Time to build the motor
quinton
1,883
Granbury Tx.
Well got everything ordered block is in the truck ready for machine shop. Oh ya found some extra parts in the oil pan! ImageUploadedByTapatalk1374076007.337438.jpg
quinton
1,883
Granbury Tx.
Parts are coming in! Thanks to Henry at creatures of the night performance ImageUploadedByTapatalk1374269949.072232.jpgImageUploadedByTapatalk1374269957.831917.jpg
quinton
1,883
Granbury Tx.
Cool, I bet your going to add more power when its done
Good luck with it.
Ya Ill be getting dual cp3 also with the 100 overs and runnin marks 72 mm charger then twin it later on. What turbo where you running with it again? I've got a buddy here that we are fixing to put the 72 on and running a s483 with it. Fully built motor and a lot of head work. Might know em Willie Lewis.
dman777
Apr 11, 2012
283
Very nice!!!! What is the date for ODRA?
quinton
1,883
Granbury Tx.
Well since I got bit by a dang copperhead Im limited to what I can do so to pass the time I've cleaned up motor parts and starting to paint everything. Also redid the wiring harness. What are you guys using to prep the motor parts for painting? Was gonna soak them all in some gas over night then clean them up with soap and water. I'm thinking all the fuel lines this sparkle red and this blue for the motor. What do y'all think? Might go a darker blue. ImageUploadedByTapatalk1375575448.248974.jpgImageUploadedByTapatalk1375575457.012820.jpgImageUploadedByTapatalk1375575464.332423.jpg
quinton
1,883
Granbury Tx.
Got bored and painted the valve covors metallic blue instead of the other blue. Motor should be done within two weeks.
