LB7: Intake Bridge, intercooler tubes and boots
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
anyone know the size of the o-rings for the LBZ intake bridge/elbow?
I wrecked mine and would rather not pay GM 25$ for a new one when Im sure I can get them for 2 dollars from mcmaster-carr. I tried the local hard ware store and they didnt have any that were the right size...
ben
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
bump...Todd did you find the o-rings at a local hardware store? I wonder if a NAPA would have them? I checked two hardware stores and they didnt have any that were the right size.
Jun 28, 2007
3,259
NE Pa
ben
The ones that I got were much smaller and fatter and I just streched them and they worked perfect. Might try a heavy equipment shop too.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
just looked around....still couldnt find any. Do you guys think I would be ok with only 1 o-ring and some of the GM RTV stuff??? Id like to put my truck back together rather than have it sit as-is for 2 days (doubt anything will be open on memorial day) because of a 2 dollar piece of rubber.
ben
3,259
NE Pa
ben
Not sure who would have one, but I used to have a kit to make o-rings. the material came on rolls and with the chemicals to melt the ends together. I would think it would be ok with 1 for a little bit, as long as you r plan on fixing it when you can get one.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
LB7 and LLY intake bridges share the same bolt center locations and are interchangeable with runners. LBZ/LMM share the same bolt center aross the top as the LB7/LLY, but the bottom to top dimension is different. I dont know how you are getting away with a standard round O-ring, as the stock units are rectangle .250"x.115".
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I dont know if you guys are still interested but Russ has finished the jigs for all the y-bridges and is going to be making. I dont know how soon but they are ones he posted pictures of in SIKDMAXs build thread.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Guess you saw I finished both jigs in the pic:cool2:? I just finished the LBZ jig last night! I had to buy a minimum of three CNC'd LBZ/LMM flange sets, to keep the cost from being doubled. Im not going to be able to knock them out, until after the NHRDA race on the 3rd though.
3,259
NE Pa
The round o-ring talk is about the y-bridge neck on a LLY, LBZ, or LMM
gonemax
Sep 9, 2009
long island ,new york
lb7 to lly intake
attachment.php
The red one is a lb7 y bridge with a 2/-1/2" pipe welded to use for a lly without emissions.The lly y bridge is very restricted in stock form compared to a lb7.the inside of these intakes are only 2-1/4" stock
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Ok, i found the runners, but I cant for the life of me fint the bridge piece.
This is the closest that ive gotten to it.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Ok, found a part number for a LB7 y bridge...however it does not turn out like the red one above. It just goes straight up.
Look at this:
