Fuel Cell Installed
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
Ill have to see, maybe your doing it wrong, I already put the tank upside down with 5 gallons in it and no leaks. Thanks for the heads up.:thumb:
4,967
He's not wrong Brian. Sloshing fuel is different that flipping your tank upside down. It's not going to spill everywhere but there will be noticeable wet diesel spots
PACougar
2,105
40
El Dorado Hills, Ca
It will be just fine ;)
The ball floats, so if fuel tried to come back up the vent, it shuts. when fuel drops back down, vent opens.
Brian, unless your rollover vent is different then mine, they definitely don't float. Before I changed my setup I had fuel coming out of the vent and mine was setup identically to yours.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
This is what I did for a temporary fix. And it's become permanent lol
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
Got everything routed/installed, put 5 gals in it and drove to fuel station, broke the cap with the nozzle. :eek::(
no sloshing out of the vent , but got home and put a 3' looped 1/2" line on it in case it did.
Also going to put a ground wire on one of the mounting bolts this weekend.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Well maybe I'll have a project for this winter now. Thanks for nothing guys!
I am looking at putting in a 32 gallon however because I'm not too worried about weight. :thumb:
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
Weighed the truck today.
3580 front
2180 rear
5760lbs gross
15 gallons of fuel (3/4 tank)
This was with my 22's, so with the radials it will be right at 200 lbs lighter.
Based on my old weights, it looks like I moved 120lbs to the rear end. Good enough for me.
