Fuel Cell Installed
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
thank you PACougar and Dracing70 for the helpful info, just picked up a 20gallon polished fuel cell this morning for the single cab
Reading through Josh's post about NHRA and mounting locations and pictures of other trucks it looks like I will be ok to mount it on the bed floor.
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
The one I ordered was foam filled but I will be removing the foam. People have said on CompD that the diesel can deteriorate the foam, if it does or does not mine wont have any regardless.
4,967
It depends on the foam. Foam from a jazz fuel cell is shit and will go bad in a year. Foam in a fuel safe cell will last waaaaay longer. There is also better foams out there you can buy separate. Race gas will kill foam faster than diesel
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
It really depends on who makes the fuel cell. FuelSafe fuel cells are the highest quality on the market, I have seen the foam material and it looks way nicer then the junk they shove inside summit and jazz fuel cells.
Now weather they are approved for diesel is another story.
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
I drag race and that wouldn't pass tech. Has to be sealed. Im not sure if that's what people have done, but after reading here a Y to tie the factory return, and my airdog return will have to do since I don't have 3 ports on my fuel cell.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Make sure you run a ground wire to the brim of the cell. All the research I did everyone said do not run foam. I never had any issues with mine. Why a 20 and not a 10?
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
Because as much as I would like to call it a dedicated track truck, it's not. I drive it too much, still need some capacity.
13,599
632
You road trip it a lot? Even assuming crappy fuel mileage, 10 gallons would give you an easy 100 mile range.
PACougar
2,105
40
El Dorado Hills, Ca
The difference in weight between a 10 and 20 gallon is so small I just don't see the point of going with a 10 if it's going to be used on the street.
13,599
632
If you're concerned about weight enough to pull the a/c out of a truck in Arizona, I would think the fuel cell weight would be pretty important too.
