why does my truck run mid 13s
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Thanks tommy ya I knew there was a PID that reads boost + atmospheric (14.7) or something Ill check into that.
And ya stock TCM.
And yes my speed limiter is set at 150 and its been to 135 so its not that.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
No I havent updated in a while, kinda scared too since i have like 10 upgrades to do lol. Still on 7.5.3
Ive logged that PID before though, dunno why its not working now? Guess first step is to do all the updates, totally lost on that one. Havent done firmware updates or anything.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Yah I had to update a bunch of crap, just read the instructions.
slowlmm
Mar 2, 2008
2,582
46
so cal
And ya stock TCM.
you need to run a modded tcm tune thts a big issue right there. tht will hold you back alot and defuel like crazy between shifts
slowlmm
Mar 2, 2008
2,582
46
so cal
Here is what I log
OK DESCRIPTION CAPTION UNITS SYSTEM CH PARAMETER
Y Accelerator Pedal Position (D) APP_D % Throttle 1 SAE.APP_D
Y Accelerator Pedal Position (E) APP_E % Throttle 1 SAE.APP_E
Y Air Flow Rate From Mass Air Flow Sensor MAF Grams/s,Lbs/Min Air 2 SAE.MAF
Y Barometric Pressure BARO kPa,inHg Air 1 SAE.BARO
Y Base Timing Table Number MAINTSEL_DMA Diesel LBZ/LMM 1 GM.MAINTSEL_DMA
Y Boost Pressure Sensor Voltage BOOSTV V Sensor 1 GM.BOOSTV
Y Calculated Fuel Rate FUELRCALC mm3 Fuel 2 GM.FUELRCALC
Y Desired Fuel Rail Pressure FRPDES MPa,PSI Fuel 2 GM.FRPDES
Y Desired Turbo Boost DESTCBOST kPa Conditions 2 GM.DESTCBOST
Y Desired Turbo Vane Position TCVDES % Diesel 1 GM.TCVDES
Y Engine RPM RPM RPM Conditions 2 SAE.RPM
Y Fuel Rail Pressure FRP_C kPa,PSI Fuel 2 SAE.FRP_C
Y Intake Manifold Absolute Pressure MAP kPa,inHg Air 1 SAE.MAP
Y Main Injection Fuel Flow Rate MAIN1Q_DMA mm3 Diesel LBZ/LMM 2 GM.MAIN1Q_DMA
Y Main Injection Pulse Time MAIN1T_DMA uS Diesel LBZ/LMM 2 GM.MAIN1T_DMA
Y Main Injection Timing MNINJTIM Degrees Diesel 2 GM.MNINJTIM
Y Manifold Pressure MAP2 kPa Conditions 2 GM.MAP2
Y Relative Throttle Position TP_R % Throttle 1 SAE.TP_R
Y Turbo Vane Position TCVPOS % Diesel 1 GM.TCVPOS
Y Vehicle Speed Sensor VSS KMH,MPH Conditions 1 SAE.VSS
ls1dmax
Jun 3, 2008
I got to Famoso late I only live acouple miles away, you left awhile after I showed up. I heard when you smashed leaving Famoso :D. Temps here are high during the day. I did a pass last night just wanted to see were the truck was at, stock ccsb LBZ with a Bully dog ran a 14.9 in 2wd :eek:, I was expeting a 16 so I guess that made my night. I ran a friends C5 afterwards from a roll and he beat by a car or two, and from a stop the truck lit up the tires and he got by about 3 lenghts. Pretty cool to see these trucks move like that, I had some passengers too. Good luck with the truck, those kind of issues are a pain but worth it in the end.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Huh? Whatd I smash? LOL Ohhh you mean out on Famoso rd? LOL I just barely got on it to pass some car who thought it was cool to do 40 down that road....... and the back end got a lil loose :D
You from Bako? Ive got family in McFarland that own a farm so Im over there a lot - Ill be back out there in 2 more weeks well have to meet up!
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
oh dont act like you knew tht before me :D but i woild agree to look into tht a vvt will build boost regardless so u may be making 32 psi at 80% vane angle istead of 40 or so. i stil havent seen the tcm question answered have you tuned it yet ? you truck should run 13.0 13.1. 12s with great 60fts 1.77 or better are you shure your speed liiter is set to disable ?
You learned me of the issue.
Thank you, pollo de cabeza.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Matt
without reading the whole thread,first thought is TQ mangement
are you getting to the line and hitting the throttle real fast? try calming down and easeing into it:) Just a thought
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
Matt
x2. And i beilve that stock tranny tune is killing you. You no longer have a stock tranny kill the defuel and torque magment and let that thing rip. It will shift hard though. Wont it larry??:eek::D
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
No Kurt.
Simon Im hitting first light and building boost and letting RPMs come up slowly then bumping 2nd light..... 6-8 seconds between the 2 lights.
Like I said this morning on my "test track" I had no problem launching at 2200 like the logs show. I dunno I guess back to the track in 2 more weeks logging.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
Yea, it will rip alright, it will rip right thru the internals of the transmission. Leaving the defuel and torque alone is the best thing you can do, like its been said before, theres no reason to fuel thru a shift, it will break things :eek:
