why does my truck run mid 13s
13,751
821
Something is wrong with your tune if you can't get the RPMs up higher than 1900.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Stock McRat race tune Josh.
Times:
Run 1:
R/T: .168
60' 1.873
1/8 8.762
MPH 78.11
1/4 13.717
MPH 99.85
Run 2:
R/T: .373
60' 1.900
1/8 8.844
MPH 78.13
1/4 13.809
MPH 99.73
Run 3:
R/T: .235
60' 1.870
1/8 8.821
MPH 77.93
1/4 13.846
MPH 97.30
Run 4:
R/T: .147
60' 1.855
1/8 8.797
MPH 78.44
1/4 13.712
MPH 100.13
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Didnt Jody go 12.7x's on the McRat tune? Id say to look deeper Matt make sure everything is correct and something weird didnt happen. Ill always help if you need it you know that :hug:. Like Pat said just hang in itll get sorted.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Im guessing something in the tune needs adjusted for to make it work better for your truck. It seems some HP is missing to only be running less than 100mph. Logs would help to see whats going on causing the drop. Maybe try running the tune that u ran befor the built trans to see how it compares now.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
X2 you should be able to break 100MPH even if your did a non-boosted launch, also what do you have to the trans or is it stock
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
I have springs clamps on.
The trans is a fully built SC4 and 1057 by Mike L, but just doesnt feel "right". Shifts are sloppy and stays up at high RPM til 5th gear or so.
5k miles on the tranny.
Ill go do passes today and log.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
You will get it. Only two things needed, get your 60' down and check your tuning. Somethings not right, is your rail pressure holding on top end?... looks like its off the launch tho. your 1/8 times need to be 8.2's or so. Tire pressure?
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
What does your truck weigh? Does the leaving at 1900 have anything to do with TQ management?
Im right over 7k when i race. TQ management is done with tuning not with rpm's i believe. Is you TC locking up? Shpuld be leavin a lil harded than 1900rpm's. I could only leave around 1900 untill i did the CIU centerlink and Caltracs.......i went from 1.89 60' to 1.76
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
I just dont get it - I was cutting 1.73 60's on stock trans and the smaller tune, no spring clamps.
Im wondering if the drag radials are slowing me down?
305/45/18 Nittos at 35 psi. When I run on stock 245s I just spin all 4.
Not sure of weight, its a crew cab LMM no weight reduction besides no spare.
Bilsteins and front end cranked down, 3" lowering shackles in the rear. Tie rod sleeves, cognito braces.
Jasons lmm cclb can has 12s with same mods and supposedly same tune, plenty of LBZ and more and more LMMs are hitting it now suposedly running mcrat race and lift pump.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
I dont think the drag radials would hurt. Suspension is a big part of it but power is the key. I would really look at your tuning and rail pressure. If your holding rail pressure then get a bigger tune. 21,500-22,000 on rails are ok on a LB7 and our desired is 23,300 or so at WOT. any boost leaks?
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Sorry to hear about your night Matt, Im sure you will get figured out. At least you actually got to race your truck:mad::mad:
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Hows this for a PID selection?
  • Accelerator Pedal Position
  • Air flow rate from MAF
  • Baro
  • Desired fuel rail pressure
  • Desired turbo vane position
  • ECT
  • RPM
  • Actual fuel rail pressure
  • IAT
  • Intake manifold absolute pressure
  • Main injection timing
  • Turbo vane position
  • VSS
Anything else I should have?
