I will be running the Arias on my truck... how often are tear downs necessary?
Just do compression tests often, Its up to you on how much compression your willing to loose.
It has a lot to do with the line bore and cross hatching that is done, And how you break in the motor. Also the rings and how you set yours.
Actually, there is a lot to say about it! Thats a loaded question Nick
Jeff,Pat or JB would be a big help if you truly decide to go this rought
