What to do?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Simon you are spot on... My truck takes exactly 3 seconds to spool up to 16-18 psi. Brian change your converter!!!
With tuning adjustment you can actually make it spool too fast and hard to controll
James
If you need that timng then try lowering fuel.
There is a small window of where we stage the rest is wot
These areas are quite seperate so keep working on it:)
5,726
James
Sounds good Simon, ill give her a shot
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
With the 2800ft difference in DA from Firebird (where you live) to ABQ (where you ran) you should be able to get some decent testing for similar environment.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Good thing you weren't in Colorado! That same night at Bandimere was 8486ft DA! And SIR in Tucson was 6560!
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
Just took a vid of mine with a DA of 4167 (1750 MSL, 85* RH of 44%). This is pushing though the brakes (and the brakes of the 4000lb dual axle trailer hooked up to it!)
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
and that is with a tight 1057, with the 37X14.5s I would leave the line at 1750 RPM and cut a 1.77. Had track prep issues that kept me from leaving any harder if you watch it does have more to do with heat than RPM, although both play into it
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Can't believe your running a 1057 but then again I guess the triples light almost instantly don't they? Only what I have read I don't have any experience with them.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
I second that the 1055 would be a better suited converter for what you are trying to do. I also think that from your video, timing was rediculous and rattled like a 3yr old doing coke
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
There is no delay in lighting the primaries, once the one in the valley lights it is smoother all the way up. I haven't gotten to drive a big twin truck yet to know how it compares, but some guys that own big twin trucks are always surprised at how easy the primaries are to spool
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
Do you run a blowoff valve with your setup? How much boost are you pushing?
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
no BOV, enough air to keep all the fuel 60 over sticks can throw at it clean. It was made for 100 over or larger sticks
