LMM: Well it finallly blew, and Now it Runs!
slowlmm
Mar 2, 2008
2,582
46
so cal
My money is on the turbo shaft breaking.
wish it was but sadly no did compresion test #8 cylinder dead a s a door nail all other cylnders looked good we kind of new when we pulled the glow pug out and there was oil on it and all the otheres where dry. so out it comes and will see wht we can do
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Sorry Tommy :(
ruffmanatv
Yeah, its got a D-Max!
May 9, 2008
3,640
46
Van Wert, OH
Dang, I thought it was looking good for you.:( Well good luck with you build. Seems there has been alot of them lately.
ripmf666
15,123
14
47
Wentzville Mo
My balance rates were fine also even with the cracked pistons.
If you have a bore scope you can look in and see if there is a crack also. Hell tommy just stick one piston in and run it again lol
9,905
151
Damn Tommy.
I go offline for 24hrs and this happens!!
Good luck getting it back together.
And I guess your right-Lift Pumps DO Break Pistons :rofl:
13,751
821
Maybe we should start a poll and see who all broke pistons and had a lift pump because I had one, and I'm pretty sure Henry and Chad both had one too...
or maybe it's a built trans because I think we all had one of those too... :rofl:
slowlmm
Mar 2, 2008
2,582
46
so cal
LOL i actuallly though about it but i guess i f have to pull the motr to change one piston i might as well change them all. unless theres away to pull it out with out removing the motor ? Heres a question if the cylinder is good do i need to rehone the cylinders or can i put my new pistons and rods in there and call it a day ?
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
You can pull the head and swap a piston without pulling the whole engine.
You are "lucky" :rolleyes: Because it is a piston in the back so you can do it without yanking the upper oil pan. Well, you should be able to. I did a #7 piston that way on an LLY ! It's half assed in a way but it'll buy you some more time....
The one i replaced wasn't cracked though so once you get the head off you can check the cylinder..... and go from there.
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
LAME! Tommy, sorry bout your luck. Like me...If i didn't have bad luck, i'd have no luck at all. If ya can afford it, make it mean!
slowlmm
Mar 2, 2008
2,582
46
so cal
you know where the truck is get to it :)
