Well I guess it's time
5,930
Wonder if they didnt put the HG alignment parts back on.....would explain the HG material you found.
i certainly wanna see that motor with the heads off. Then id like to punch the guy worked on the truck "right in the mouth!"
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Well, gotta call Guy to see what I can do with the spare block and crank. So far he will be cutting the low mile pistons I have, new rings, and new water pump. Depending on what I have into it, I may have him assemble the short block. The block/crank has been mag'd and are good to go. I have all the bearings as well and rings shipped today. Need to sit down and talk to Guy and see what route is best to go.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Im feelin strong... got all the converter bolts and bellhusing bolts, engine is ready to come out whenever I buy a hoist:happy2:
Mike... tell Rodger to turn his gun down a notch or 2 :eek: :spit:
15,681
Brian you can't do this kind of work with 1/4 inch drive tools. :rolleyes::roflmao::hug::D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Says you who needed my help to hold your engine from spinning breaking your converter bolts loose :D took me 15 mins by myself :D
5,930
Wait a min, i distinctly remember you sitting under my fender watching as i held the balance bolt with a breaker bar while videoing and hopper busting the bolts loose while you damn near hit the fender when they cracked loose.
I have video proof!!!! Lmao :D
durallymax
Apr 26, 2008
2,756
Under The Hood
Im shipping you a cookie.:thumb:
It's a wonder you two get anything done.
Ever try using an impact to remove them? Yes you have to use some common sense operating it, but it's fast. Turn the motor over by the alternator nut. With a long ratchet you can do it through the fender liner. This is nice when you have a lift. Put it at a comfy height and away you go.
5,930
Tried it. Harbor frieght extentions flex too much and take all the torque out of my half inch impact lmao. Plus its much for exciting wondering if the extention is gunna break and yiur buddy is gunna get bloody knuckles or if the bolt will snap free and he still gets bloody knuckles. Either way, i laughed my ass off.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Lol clowns
Try breaking them loose with a socket and 18" extension.....nothing else :rofl:
Taking that motor to socal soon???
THEREDDEVIL
A Bad seed
Jul 28, 2010
512
Godfrey, il
So lets say the previous owner knew he had bad injectors, yet kept driving it. Then after x amount of miles decided to have them replaced. Would the comp test look like this motor? Figured its a good time to ask with the good brains that r in this thread. My dads buddy has an lb7 that he's been driving for like 100k miles on jacked injectors. He's finally getting them fixed but it seems like a lot of damage could b done driving for so long on bad injectors.
