Water Pump Danger.
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
I have a billet aluminum impeller that we use on the high rpm dodges that could be used on the dmax.. with a .005-.010 shrink fit I think it wouldn't go anywhere.
I've thought about shaving the impeller down a bit to lose some efficiency so that it doesn't want to spin on the shaft at high rpm. I'd venture to say at 5000 rpm the water pressure is getting pretty high.
IdahoRob
Jun 5, 2007
1,151
Best thing is if the impeller comes of, bad thing is when the drive gear falls off and destroys the cam gear.:( Weld them up, mod down the vanes, run the McRat themostats.
3,733
305
Hmm, I might have missed it, but I just read the whole thread, so I'll ask:
Some of us like to tach the engine up to 4+ grand when grade braking (me), is that going to kill the water pump? Or is it a combination of the high RPM and heat output during a race that causes the high pressure?
Should I avoid letting the engine grade brake above redline (3250), or do you think I'll be OK?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
If the pressure is getting high why doesn't the cap let coolant out of the over flow?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Because it is on the wrong side of the restriction.
Right so then it would be a good spot on the ps rear cover to put a gauge and relief valve it would easy to tap and throw a check valve in before the gauge then just check it at theend of the run to see what the highest press was
I've seen some trick lil pop valves that are fully adjustable from 0-100 psi in 1/4" to 1" npt and then you could run a hose to a pop bottle
tractor
293
9
59
Spring Creek,NV
I have a question about water pump volume.
When I used to build ford gas motors we used to take every other fin off so we could get more volume.
Would this have any benifits on a DMaX.
Thanks Darryl
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Haven't been on at all in the past few months but got on to order some thermostats from Kat.
I am confident that I am the "poster child" of this thread at this point. I had the stock pump's gear let go back in October during a trip to Mississippi towing a Mustang. I changed it in the yard when we got there but didn't have access to a welder so I just stuck the Advance Auto pump in as is and went. It lasted until about mid April and I don't remember if it spun the gear or impellor. Since then I have put more water pumps in my truck than I have tanks of fuel, trying something different each time with nothing working so far. I've arc welded it and had the impellor break from around the weld, MIG welded and had the shaft break off at the weld on the gear side, welded with less heat both MIG and arc and had the weld break off the shaft or impellor. I've been wanting and trying to have it TIGed and one guy brought his MIG instead and thought he knew better, another that I left the pump with said he TIGed it but it had spatter marks on it from flux core MIG wire, and the machinist I took one to (which failed yesterday) cut a groove around the end of the shaft to get a deeper penetration, then he MIG welded it because he didn't have the proper TIG wire, and even worse he douced it in water as soon as he was done to avoid hurting the seals - at least he did it all for free since he wasn't sure if it would hold up.
Yesterday, I finally took one to the machinist I trust out near my old shop and I'm pretty sure his will hold. He also cut a groove on both sides for better pentration and on the impellor side drilled a hole along the shaft, taking half shaft, half impellor. Then he pre-heated the impellor, since it is cast, and TIG welded it, filling the hole and in the grooves on both sides. We kept cold wet rags around the outside of the impellor, gear, and housing to keep heat from soaking to the seals.
We discussed other options such as keying and pinning. The shaft is hardened and very tough to drill through; but carbide bits will do it. If you use a small roll pin perpendicular to the shaft I would worry that it would break, especially with some of the welds that I have broken. If you use a hardened pin it will hold up better but you need to make sure it is a very tight press fit to get it in. If it isn't and the interference fit breaks loose so that you are actually using the pin it will slowly beat itself up until it breaks. The other option is to drill half shaft and half impellor/gear running along the shaft to "key" it with a round hardened pin (similar to the Empire crank keying setup). Again you need to make sure it is a tight press fit and I would use green loc-tite (must be heated to 550* to get it to let go) to prevent it from ever coming out.
I think that the lower temp and especially faster reaction of the thermostats will also help cure the problem. I have been trying to let the engine get fully warmed up before doing any playing but even so they are breaking during or after me being hard on the truck. With the S480 single when it lights the truck takes about 2 seconds to go from 2500 RPM to close to 5000 RPM (typically breaking the tires loose regarless of speed) - I think that part of the problem is that hard of acceleration (change of speed and inertia of the impellor and water it is pushing) and the fact that the thermastats are closed or only partially open is causing so much pressure at 4000+ RPM that it just breaks the weakest part of the pump or the weakest weld. Believe me if you get the impellor to hold you will get the gear to break loose, and vice versa. I will try to report back on if the TIG welding and thermostats together solve this issue. I'm pretty sure I'm on water pump # 9 and the last 7 have lasted 6 days on average - so if I can get one to hold I think the same things should work for everyone else.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
Wouldn't it be easier to just make a pressure relief?
I figure the thermostats are a better place to start - they will give me the benefit of more coolant flow during races and could possibly fix the water pump issue all at once.
If this one with the new thermostats doesn't hold I am either going to go electric and set it up like Simon's or do as some others have suggested and put a pressure relief in the passenger side coolant block off plate that will bleed back to the radiator. In my opinion if the thermostats being closed is the problem you would need a pretty big pressure relief line though.
2,064
Geezus Dustin. 9 pumps? Were they all "aftermarket" rebuilts or were some OEM new?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I think the T-stats have helped me more than i know , still on the same pump I bought the truck with , it is getting replaced due to a leaking seal , and the next one will get welded so we'll see if it keeps going well ,after thinking about it , my truck has had the t-stats in before i even ran it on dual cp3's , so far so good !!
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
Sounds like it is a good fix. might have to add them to the build.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
They were all from Advance Auto - they have a lifetime warranty so I haven't been paying for any of them, surprisingly they just keep giving me a new one. I have put Advance pumps in for quite a few customers with no problems from trucks with stock motors and less power.
On the note of aftermarket pumps - back when I replaced the first one Tony Burkhard had advised me not to get one from NAPA, saying that the gear is cut wrong and doesn't mesh with the cam gear correctly. Since then I have talked to a few people that used NAPA pumps and said they whine like a supercharger.
As far as machining the impeller down so it moves less water, the one currently in the truck is the 2nd one I've done that to. This time I went pretty far - the outer tip of the fin to the back of the impeller I took down to 16.3mm - it starts at over 20mm; the inside tip I took to 17.5 down to the base - it starts at over 21mm (based on where I measured). I drove over 5 hours yesterday, all of it towing - with 2 hours of that towing another Duramax. I still don't have the new thermostats, and have electric fans that you "can't tow heavy with", and am running an S480 with an 87mm turbine as a single. Towing the truck EGTs were 900 on flat ground to 1100-1200 up the slight hills I encountered - I wasn't downshifting to keep it cooler since they weren't getting too bad in 5th at 65mph and 1700RPM - but definitely tasking on the cooling system. It was in the mid 80s yesterday. Coolant temps (according to the dash) and oil temps (measured before the factory or auxiliary coolers) stayed around 190*. Towing a lighter load later on the coolant and oil temps stayed well below 190*. So IMO you can take a lot off the impeller (nearly 1/4 of it) with no ill affects daily driving and towing, and my hope is that the reduced weight and reduced "grab" on the incoming water help reduce the load placed on the shaft. And it was also in a housing that has been loosened up by multiple impellers coming off the shaft and grinding into it, then me smoothing it out.
