Twins with Twins, Anyone?
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
Somewhere On The Ohio
www.marinemods.us
And the closest to actual retail weight without going over is, TheBac..
By time we add all injectors, accessories, fluids, wiring and such, I'm guessing 1550 total package.
Sent from my SAMSUNG-SM-G890A using Tapatalk
13,736
806
My transmission buddy didn't recognize it as anything common. Too beefy. Luckily it's in good shape. Inside filter is dodge for sure.
He must not work on many Dodge pickup transmissions or something. Unless the picture is very deceiving, that is exactly what they look like.
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
LoL.. I agree with that picture.
Yeah had at least 3 parked on the lot when I was there. We got to looking at the the planetaries and drum, which must of made it look beefier.
Thanks, that completes the rebuild parts list.
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
Few more pics showing some of the clearance considerations we had to work around. Biggest being turbo to hatch "acrylic" pannel.
Also upgraded all the hose clamps to 316 SS Tbolt. Anyone wanta guess price for all those clamps??
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
Ok new issue for the week.
Turbos set 6" from the acrylic panels in hatch. With a 180F max continuous threshold, and a 250F molding temp, can see possible problem with using plexi now. Unless I shield the turbine and compressor housing. Which I would hate to do..
So where would one look to find some 3/4" glass panels custom cut to fit??
2,237
McMaster Carr is your friend
https://www.mcmaster.com/insulation
They have ridged, flexible, cloth, strips, moldable, high temp, medium and low temp, etc
But if it was me I'd secure some mineral wool up there. It is probably the best insulator for high temps. Better R-value them ceramic, fiberglass, silica, etc. And cheap too. Can get it at most hardware stores where the fiberglass is found
You can get foil backed version at grainger: https://m.grainger.com/mobile/produ...ineral-Wool-Foil-19NE81?breadcrumbCatId=28202
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
Trying to avoid wrapping them if I can. I have blanket for turbine side, but from our dyno data, the air exiting that compressor is 500F. While under power the turbo should be moving enough air from that area, and there is vents front of hatch.
So my biggest concern is heat soak when slowing down. If I switch to real glass panels, that becomes less of an issue.
2,237
LB7 must of hacked my computer. Awfully close on his guesses.
My job(s) always seems to have me making snap judgments. "Need that information right now", "how do we take care of..." kind of stuff so after a while I got good at it. As long as it is something I can think with and have at least some experience in. Seems everywhere I go people are asking me questions.
I always thought, make yourself valuable and figure out how to do something no one else in the company can do and you are less likely to be laid off. This was one of them
2,237
I was thinking that you wanted to cover the back walls with the insulation. Are you thinking free standing insulation or securing it to something? Or are you thinking actual glass like window or safety glass, etc?
