You get the S476 with the LI wheel? I've had pretty good success running the 1.1 T-6 83 turbine wheel. Even tried the S478 LI on a truck, was impressed how well it spooled. Those turbos are priced right for those on a budget. We did one truck at 1000rwhp, with a little spray, so you'll blast thru your 600rwhp number.
You done anything with the internal gate on the GT37? What pressure you going with boost actuvator? I like to run 24-26 psi just to start opening the gate. Which GT37 you going with, looks like a GT3788R one off a 3rd gen dodge? We have massaged the turbine housing around the wastegate flapper for more flow and some flow smoothing.
Another good choice is the S480, tried that as well. Abit more lag.
