Haha oh dear :roflmao:
I read that I swear. Did it come with a flow sheet?
A set of 100 overs ran at 1700us and 160 mpa give you about the same fuel that stock injectors do ran at 2800us and 180 mpa. Pressure is a huge variable. I wondered why you were running 160 mpa on your tuning.Tuning is getting very close. Took a log of a soft 5psi launch on tune 2, 1650usec, 190mpa. Per the log it went 0 to 100mph in just under 7.3 seconds..... if that is anywhere accurate, which it should be considering the speedo is dead on, that is a deep 7 sec eighth.
I'm getting more and more curious about these injectors. I have the receipt from ii for 100s but they aren't really acting like 100s to me. They love rail pressure, the difference between 160mpa and 190mpa is incredible.
MOST people don't need to be doing wiring
Haha.. fixed it for you...
You wouldn't believe some of the stuff I see on people's boats...
:rofl: My boat was a nightmare to figure out but Im happy with how it turned out. I was dealing with a new boat so that helped. I couldnt imagine restoring one someone else had their hands on.No kidding. I'm in the process of a cap off resto on my Supra ski boat. It was like a team blind epileptic's wired that thing. Every color of wire & connectors were used
You don't want to see mine. I was rushing and it came out terrible. I need a new dang pillar and then I'll rewire mine. I'd be curious to see what some of you guys wire up pillar gauges like as I'm gonna need some direction
I prefer to run one positive, one ground, and then splice everything in the pillar so there is less random wires running down the pillar.
Me too. And one wire from the dimmer lead on the back of the headlight switch to split off of for the gauge backlight.I prefer to run one positive, one ground, and then splice everything in the pillar so there is less random wires running down the pillar.
I might have to do that. Mine is a mess.Yup I left that part out.
Actually installed some isspro ev2 gauges in a dodge the other day and hated the way they make you wire them. Had to run like 18 different wires because they make you wire in the harness.
Don't push me man, I won't go past tune 3, or 4, but definitely not to 5, unless it doesn't go fast enough.....Peer pressure is a bitch. Lol
