The Build: 2001 ECSB Silverado 2500HD "SS"
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
Remember that you will need a certain height between roll bar and seat
Also remember ps and ds are different bases
Nancy negative speaks up
The seats should end up in the same spot as stock. Hopefully. Forward/backward movement would probably change slightly. I thought about cutting off my stock bases and just adapting them
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
too heavy!
i realize tim they will be in the same spot but height is perhaps different:hello::)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
oohh, I'm following you now. how should I go about it then?
Best would be to have the cage/bar in the truck then sit in the truck with your helmet on.
I cant remember the distance off hand but there needs to be a certain measurment between your bar and helmet
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
x2 , plus the door bar has to pass in the middle of your elbow and shoulder with the driver in the seat .
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
I was aware of the door bar rule: crossing between the shoulder and the elbow. But the measurement from the helmet I thought I read that was in reference to the rear cross bar. I'll have to go back and re-read it
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
Note to self:
Vinyl Floors are a pain in the ass to install!
especially when they are supposed to be "Custom Molded" for an Ext cab and I get it and it's for a crew cab...good thing I had extra razor blades....
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
don't worry thats normal.... if anything goes right on that project i would really start to get worried.....
maine04max
Dec 11, 2008
1,009
Any N.E.D. get togethers coming up? I just ordered some new proxies and cant wait to get some new best times
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
I hope I don't run into the same problem
problem was that they were molded for a crew cab which has the floor ducting....not what I ordered but I ordered it from a place in Alabama and wasn't about to wait another week to get the right one...I used a small torpedo heater to get it all warm and got it molded the best i could. I had to take up some slack in the center over the tunnel but it's covered by the new aluminum console anyways.
