I was thinkin today and i kinda overlooked somthing on the pinion snubber. In the case if anti-squat ie, your best friend, the distance between the snubber and contact point wants to grow and thus forcing tires into the pavement harder but i overlooked that under lots of weight transfer like a hi-power car like a pro-mod, still haaving anti-squat it will still compress the rear suspension. so a pinion snubber would work but at this point with proper suspension and tuning of it, it kinda makes it just a susp travel stop. I see anti-rotaton advantages of it to be small, main benift is its applied to the pinion and could reduce some stress on the axle housing, is it a worthy amout or neglible, i dunno? And also, say its set stop rotation, compression at a given measured distance, it might not achive the same distance of compression each pass due to conditions...if theres a gap it can give it the opportunity to axle wrap, not enough compression distance is gonna contact early and stop suspension travel making it a more or less solid susp. Im not tryin to shoot down ur ideas or anything, im just as intrested in the best possible setup as you guys, i just see it as, why do with a pinion snubber what proper traction bars and or suspension design can achive more efficiantly? I'd sure be intrested in test results and would love to be proven wrong:hug:
