fabbing????????? that wood working my friend :rofl:
look like a good idea...only thing i would be worried about is it rolling on you.
pending on how thick you piece the snubber is attached to you "could" bend it
2 the torrsional rigidtiy of said crossmember.
the idea that i see is it shoving up and rollin forward over the top of the xmemeber.
i cant remember how rigid said piece is
Interesting post in Chassis concerning shocks: http://www.duramaxdiesels.com/forum/showpost.php?p=78131&postcount=51
So running the Rancho9000's set fully stiff on all 4 corners like Jess said is the way to go there?
Yeah, we had discussed that before. There might be too much stress on it. If the snubber was mounted at more of an angle to the diff then bending would certainly be a possibility, as Mike stated. Rolling the stand on the crossmember is a concern, too. If this is a feasible design, I think I'll start by using the U-bolts, though. That way if it does twist, I have an out, but Im not marrying myself to the design by welding it. The only way to find out is to make one and test it.
I dont think the crossmember is going to be an issue. Its a 3" dia thickwall tube. I cant see the rotational force from the diff being great enough to bend that.
John, just trying something different. I can always go back to Caltracs.
"Full stiff" is a subjective term Tom, not knowing what the valving is for those shocks.
Within the next month or so (man am I optimistic!), we're gonna play with some stuff on the shock dyno to try to get some more information on chassis tuning these things.
By the way, if you get a chance sometime, try to scale your truck in race setup. Get the front axle and rear axle weight.
looks good bac , i'm interested to see this baby in action , and i agree only way to see if it works is to build it and see , good luck , if it doesnt work out for ya the set up i just did i think is going cut some very good 60 times this coming spring traction is far better than it ever has been in 2wd . keep us posted
Talked with my fabricator today. He looked over my model for a little while, asked me a couple questions, and came up with another idea.
He's going to use a piece of 3" ID double-strength pipe cut in half as the base. He'll weld two arms off 1/2 the base. These will be mated to a TBD-sized 4" long tube (think "triangle"). He'll use the threaded rod thru that tube as the snubber mount.
Here's the part that clues you to why Im not a fabricator, because I didnt think of it:
He's going to drill two holes thru the base pipe and the crossmember and use 1/2" grade 8 bolts's to pinch the base around the crossmember. Solves the mounting AND the rotating problems in one neat package.
So hopefully he'll have something for me to test fit in the next few days.
Shock dyno? Whats a shock dyno?
