suggestions rail pressue
LBZMIKE
Nov 15, 2014
62
colorado
Ok got another question how can i go from lift pump straight into my cp3 i have seen the fittings but my main question is the FICM what needs to be done there or will it even matter to go to 1/2 to the cp3 also what about a fuel tank sump ? Good idea i no the draw tubes on the factory unit are undersized what would you guys suggested...thanks
The Neens
BFD
4,596
Monrovia, Ca.
Your truck doesn't have a FICM...
LBZMIKE
Nov 15, 2014
62
colorado
I would imagine going directly to the cp3 would be the optimal way of installing the lift pump but at what power level will it begin to benifit the motor ? And also the suction tube in the tank when is that going to be beneficial
6,052
Over 1000hp would you need to worry about it. I wouldn't even mess with the stock pickup tube
