suggestions rail pressue
LBZMIKE
Nov 15, 2014
62
colorado
I understand that im saying im going to use it for the monitoring just like when the sell efi live and edge cts insight i will keep my edge on stock level and use it for gauges
christopherglenn
Aug 26, 2012
46
The FPR is loose, there is a fine line between loose and broken. Unfortunately you need to move closer to broken. FWIW It took 4 or 5 tries tightening mine (shim) to get it to hold pressure.
6,052
The edge on stock isn't really stock.
LBZMIKE
Nov 15, 2014
62
colorado
I will try to crank on her some more lol and if i put the edge to stock ...and unplug the tuner to lets say sell the tuner how is it not stock ...?
onebaddmaxxx
1,212
Cecil County Md
If the relief valve is not tight there's your issue....you need to run stock fittings. Higher volume = less pressure. Put stock fittings back in.
And you won't be using the CTS to control tunes on an 06. They will only work as gauges.
6,052
Curious about this comment, just trying to get educated. Please explain.
it still adds timing to the stock tuning. pull your edge completely off and you will notice a difference in power and mpg between edge stock and actual stock
6,052
For the non believers that ported fittings are a improvement this test was done by fleece performence stock fittings lost around a 1000 pounds of pressure
http://youtu.be/3J7ZoQrKbzA or type in ported fuel rail test
i gave you a good run down on how to actually diag your issue and not just "put stock stuff back in". quit worrying about what everyone is telling you to replace, they are not there. if you cant give me that info, your gunna be spinning your wheels (or wont be in this case)
LBZMIKE
Nov 15, 2014
62
colorado
Ok so I got the race valve as tight as I could with a breaker bar and it will hold 22000-23000 when i punch it but if i sneak up on it it will hold 24500-25500 my filter head plug for the fuel heater also leaks i forgot to mention that i got reminded this morning also my filter life says 49% and a month and half ago i bought the truck it said 100% could it be somthing to do with the filter ??? Oh bottle test was negative
6,052
thats a much better sign. what level of the edge were you on? yes a plugged filter can cause all kinds of fueling issues. its like changing the spark plug on a 2 stroke, when they start running like crap, its the first thing to look into.
LBZMIKE
Nov 15, 2014
62
colorado
Thats on level 4 100hp tune and my truck will loose prime jf it sits for a couple days would the leaking fuel heater cause this issue cause when i go to reprime it it will spurt fuel out of the heater plug
N2BRK
2,076
409
your filter % is artificially low because of the leak at the FPRV. Now that you solved that, it should work properly. Mine was loose on my first try and I went from 100% to 0% the first time that I punched it, lol. Mine is an LMM but it's the same thing :)
6,052
yes it can.
LBZMIKE
Nov 15, 2014
62
colorado
Well my fass 150 should be here next week and i want to delete that filter set up any suggestions on the best way to do that?
moparkxracer
2,309
33
Out and about
you can get a fitting that couples the two lines together and just unbolt the filter housing. double check all the fittings when done, they are not used to having the pressure behind them due to cp3 sucking fuel.
CarolinaHD
969
NC
Use Dayco #71359 to connect the 2 hard lines located under the grid heater. Follow the rubber hoses from the filter head to the motor and you will see it.
