Simon's new test mule
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
It doesnt seem to be air:( but there is a lot of pressure
HEAD GASKET imo:mad::mad::mad: damn i go through head gaskets!!!!
not sure if it was bad or something I did on the install I took my time doing it and you cant really put them in wrong as long as the holes line up
Not sure we will do a few tests tommorow but im thinking the heads will be coming off
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
OK blonde ? There isn't a way the thermostats could be installed backwards could there be?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
its possible when GM rebuilt my motor they installed the 2 dots backwards
or actually forwards and made my coolant swing all over the place
but i checked that this morning Kat...Hopeing i scewed it up
In the morning I will pull the glow plugs and turn it over,If I see coolant spu out the heads will come off:( I just cant see any other reaon for the massive pressure and over heating
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Does the engine seem to be hydrolocking on a cold start Simon? I can't see it being a HG. Has to be something simple, I hope:eek:
starts fine
Sounds like a head gasket on upside down or on the wrong side. :(
checked the tabs on the gasket and they are correct
thankfully i took pics of the build and zoomed in
also no coolant out of the glow plugs but i do have a lil fuel out of 1 cylinder
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
well im at a complete loss now? ive talked to a few people and we have gone over everything?
everything people say ive done or replaced:(
what to do now?????????? I did call Dave at BMS and he said he would try and think of something but was also at a loss after i told him what ive done and trippen also helped with some diagnostics but all tests came back good?
paint94979
Beer Nazi
Sep 18, 2006
11,715
Have you completely narrowed it down to the cooling system?
big_jon00
Junior Member
Aug 9, 2006
30
42
DeForest WI
Simon sorry to hear of your luck, I must of sent you some of mine with the parts. If it wasn't for bad luck I wouldn't have any. That sure is strange, :confused: someone didn't forget to take out a rag or plug:rolleyes: that would be my luck..
Good luck
Jon
9,906
152
I got an idea Simon that involves a webasto water pump to do some testing.
Tomorrow.....
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Ive thought oil heating up the coolant but that doent explain the low to no flow coming from the water pump bypass to the heater core
Good luck
Jon
Thanks Jon i normally have bad luck anyways:) shouldnt be any rags but im going to check just to be sure
Tomorrow.....
Ok dale ill try what ever Im also thinking to check the rad for obstructions just to rule that out also bypass the heater core
jack up the front of the truck to fill like we do with the sleds sometimes
move the coolant tank
could also try useing the washgun to finish the fill thru the 3/8s port on the upper rad and just turn down the pressure....maybee
it was a nice thing to see the pressure never dropped on the coolant tank today and no coolant coming out of the glowplug holes,,,,but im still worried its a gasket
