Simon's new test mule
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Thanks Kat ill start working on it tommorow Im on my way to get my new laptop fixed.....3 days old and allready fubared:mad:
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Nice Pic's :hug:
New Vista computers bite :mad: We bought Allison one for her Birthday it has crashed twice (
9,906
152
Drunk in Moscow in the business class lounge right now Simon. Flying to Germany to deliver a parcel to Lennart, then I'm home tomorrow afternoon.
Gotta go and pick up my truck in Stettler from the hospital and then get the keys to my new house!!
Then I have to go see Ted for some reason.......
Are you working right now.
Oh yeah, that stack looks BITCHIN!! How do you think two of those in my truck will look?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
ok
thermostats pass the test:( thinki8ng waterpump
when you pull the heater hose off the firewall shouldnt there be coolant pumping out?
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Only when its running! :poke:
Damn Simon, my heard sank when you spoke the dreaded "H**d gasket" words! I really hope its the water pump. It worked fine before you had it apart though, didnt it?
I know you said you finally got it into 5th before it got hot, so I'm assuming you havnt beat around on it enough to even blow a gasket yet. Good luck!
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
water pump is new oil cooler is stock
what makes me think water pump is no pressure on the heater hoses and no heat in the cab
i just got the water pump off the spare motor and 1/2 of my truck apart
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Are you sure there is no air lock somewhere? I'm sure you ruled that out a long time ago....
that was the initial thought
I dont get it the pump is fine? not spun on the shaft:confused:
we took a heater hose off another truck just to verify that there should be pressure on the heater hose into the cab and YES there isa pressure there
something is restricting the flow???
im not sure what to do now?:confused::confused:
MaxFarmer
<--Heavy Smoker
Jan 22, 2007
1,251
45
Albion, Nebraska
Man, you're gettin beyond my knowledg scope now! This sucks! I suppose you have to start tracing back. Radiator flows through ok? Flows to thermostats ok? Radiator return?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
it has to be air?
going to buy a part that will put the system on vaccum and try that
you can blow coolant and it flows freely?????????????? It has to be air cause i dont know WTFFF else it could be:confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused:
