A course threaded 3/8 nut should not even be near a Duramax. What could you possibly use it for?
Carelessly tossing around open ports on a built motor of course that's what I use my coarse threaded nuts for...among other things
Guy, I tried to call you but I dont have your cell and the shop isnt taking messages. Ill PM you right now. Thanks for all your help.
I need someone down in the LA area to get my head and drive it from PPE to SoCal Diesel. Anyone that can do this for $$$?
Got a call from Dan just now. They got a lot buttoned up last week and today:
Fuel Filter relocated to under/beside the big turbo.
Custom coolant overflow tank
Rerouted a transmission line that was run incorrectly (I would assume this was my fault)
Straightened out the PPE dual fueler - was at a bit of an angle I guess and could have caused a squeak.
Corrected "all of the incorrect wiring" along with moving the battery up front, starts fine.
Wrapped downpipe
Custom fenderwells
Added bracing to the big turbo - what was done was insufficient
One of the hot pipes ( I think) was rubbing up against another pipe - this was because the angle of the piping when built was incorrect and was causing a "massive boost leak" - 1/8" gap or so. The pipe had to be sleeved and extended I believe is what he said and Ill have to rechrome.
The downpipe of the small turbo is touching the firewall unwrapped so now they are having to pull the turbo off and fix that issue and wrap it and then put it all back on.
So, more than likely Wednesday or so Ill be looking at a completed truck - just a week or so after taking it down to the guys at PPE. I imagine Im going to be out some big $$$$ but the job will be finished up professionally by a first class operation.
What would have happened earlier?
That nut has been in there every times its been run since it came back from Russ.
Sorry, but you just dont have any idea whats goin on here. This was obviously the "tick" that Dan said he heard immediately, that I posted here was thought was a cracked flexplate.
Compression was checked before any bolt was removed on the engine - Cylinder 5, the cylinder that this nut was found in, had 50 psi. You telling me that the nut holding the valve open wasnt in there until they tore it down to solve the 50 psi issue? Riiiight.
Im sorry to say, but it has been very misleading. I dont blame him for not knowing whats going on, at one point and time, the starting issue was fixed, and the turbo pipe had to be fixed and wrapped and it was going to be done. Then a few post later it had a tick, so yes, he could have easily got confused. As far as the finger pointing game, its easy to play, but it gets old. Everybody is human and makes mistakes, not one diesel shop/fabricator is perfect in this world... also everybodys opinion of complete and done the way the want it is different. We had to do a lot of work to PPEs twin turbo kit they sent me to fit my likings, how stuff fit, drive pressure maxing out a 150psi gauge, and buying a few clamps, some hoses, some wastegate piping and a wastegate to finish it up, but hey, we got it done, and it looked and ran a lot better after it was really done and then it was truly a good twin kit, I see that they have improved all of that since i have got mine by looking at Dmitris (which i would hope), thats part of the game, you live and learn. Like I said, its always easy to point fingers, that doesnt mean its the best thing to do.
is that comment really necessary?
One question. Did you find a 3/8 course threaded nut that went through your intake hanging up a valve in your engine? Obviously not.
You posted a lot of mumbo jumbo and got totaly off the track. Yes new products need to be changed and dialed in to a truck to do what you need it to do. The nut in question is not part of the equation. How do you make changes to the nut position? Move it to better place?
I did not accuse Russ of doing this only asking a question.
Trent may have hit on something about the turbo kit using that kind of nut. Who put that part together and how long was the intake exposed uncovered?
As far as not being able to crank the truck with the single battery; battery cable 101 would have given the person an answer.
Now thats a lot of mumbo jumbo, but i would turn it counter clockwise
But you didn't answer the question. You just wussed out with bullshit. Can't answer it can you?
I will refresh this. Did you have a nut under your valve with the PPE kit that you had to address? Simple enough? No names, no blame. Yes or no.
Yeah, I wussed out:spit: No Mike I did not have a nut under my intake valve :thumb: But the installation was done by me and others, that way no fingers are pointed.
