Seriously?
617
From comp D:
He updated his Facebook in the middle of the night and said throttle hung, air shutoff setup didn't activate properly, initially looks like 2 rod bolts failed, then whole the rest was still at full tilt it split the Hamilton block off the rotating assembly section.
Read that rack hung, went to neutral and the air kill failed to work
Trimox
156
14
The link works for me. I don't have fb either I just hit not now and it works with a little bit for the screen blocked.
And ouch! Glad the driver walked away.
2,218
Video now works :)
Looks like the first 3/4 of the video is filmed with a potato though then it gets clear. Maybe ots a buffer issues on my end
Lowboost
Nov 12, 2017
24
Called the local junk yard looking for a 4l80e. Pulled up and this is what they were gonna sell me for $1050. No thanks, it’s probably ok,,,,,but I didn’t want to chance it.
Lowboost
Nov 12, 2017
24
Looks like someone dropped it, it broke and then a 12-pack later "wallah". All fixed.
Yea. I’m thinking somebody tried to pull it up tight w the bell housing bolts and ran into a tight spot.
Blackmax123
683
central Pennsylvania
Being from a junk yard, I'd guess it is out of a wrecked vehicle. That's probably the damages from the crash and they repaired it to sell.
Could also be as you thought because I've seen guys do it. Tried installing it without the converter fully seated and tried to draw it in tight with the bolts till they realized they had a problem.
But I'd stay away from it for that price.
2,218
Picked up a C3500HD yesterday.. owner goes rear main brake line had a hole in so I replaced it... I said cool thanks... :woott: :rolleyes:
Dam, that is something I would put on my fridge ice maker not a brake line. Maybe if I was stuck in the middle of nowhere and thats all I had but not for long. Not DOT legal by any means
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
That’s what I want to swap into the TBSS... Need to find a reasonable priced one though.
It's amazing how much they take in stock trim. It will chuck a weird shift every now and then but it's only after I've pounded on it or driven it nicely then whacked it...:spit:
