I get 606 HP for that run.What's my calculated rwhp Steve? Et and trap is in sig. Weight was 7020 the day I ran that time. I'm assuming I'm over 600?
What was your 60 on the 12.41@110 run?
Or rather I should ask, what is the highest mph you ever trapped regardless of ET?
But yes Crenshaw at that speed and weight I would like to see your compression test results.
So basically, after reading this thread.. Your motor is about to go BOOM!
So what exactly is considered low compression? What is a new engine make for compression?
I'm about to go buy a compression tester and I will post the results. If I'm low on any cylinder, I will put my foot in my mouth and eat all my words.
My motor has grade c gaskets and 161,000 miles.
Drivers bank was 390, 395, 400, 385 pass bank was 390, 400, 405, 395. Used a harbor freight tester when engine was warm. Balance rates are also -+ 1.0. Did the test last weekend. I thought those numbers looked pretty good but I also don't drive it like I stole it.
15+ with 108+ and probably 40 passes 104+ when I turn my tune down for TNT fun.
You are borderline so I would expect your weakest rod/rods to slowly get shorter as you run more of the max effort passes. If you stay at that power level they may just shorten a little bit and stay there.
400 is about what a lly/lb7 make new, 380 is what mine made with lower compression pistons and not quite broke in fully. 330-350 and lower and your on bent rods. 250-270 puts you in pistons hitting crank and lots of white smoke, 270+ puts you in the haze territory. this is all based off my motor and others ive read about.
inbetween 350 and 380 is "iffy". a quick shot of oil in the cyl and a rerun of the compression test, then a leak down will tell you if really is rods starting to go, rings worn, or a valve not fully seating.
