LB7: Rod limits
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I just hope the guys joking understand that they are lucky and should not recommend anyone to run big power on a stock motor and call it "reliable".
Kyle windowed a block, but he was pushing well into built motor territory. He accomplished some great times even for guys with motor builds.
I really don't care, I enjoy the motor build threads!! :roflmao:
DMAX497
Sep 27, 2012
398
Utah
You are one to talk... We all know your truck and how hard you push it :woott:
rcr1978
790
Spring Creek, NV
Alrighty here are my compression test results.... 05 lly, grade c gaskets, s472, 30% injectors, efi, always ran on my biggest tune and ran hard every single time I drive it. 161,000 miles. Towed a goose neck it's whole previous life and the last 25,000 miles i have owned it, it has been abused. What do you guys think?
#1: 360 psi
#2: 370 psi
#3: 360 psi
#4: 360 psi
#5: 390 psi
#6: 360 psi
#7: 360 psi
#8: 380 psi
Don't forget you are at 4500+ft naturally your numbers will be lower than what these guys normally see I will see if I can dig mine up I'm at 5500ft
