Riddle me this..
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I still think your converter isn't locking.
I do as well. Seems like ben's box only works on the low RPM range. Seems like the ML converter locks pretty softly in my case. Definately not a 1058 or Junkstar :angel:
have you tried replacing the fuel pedal/steering wheel/brake pedal interlink logic unit with one that works? Yours sounds defective
Driver mod did not help either.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Doesnt look like the box is working atall by the first logs. Not that his box is the actual problem, but it just couldnt mask the issue. When my ml force locks it will bark the turbo, you can deffenately feel it lock hard. If you log turbine and input its much easier to watch tc slip on a log than using tcc slip pid
Ryan T
1,007
CA
Cross your fingers boys.... so far shes shiftin better and better on my tcm
this is good to hear, my truck used to shift perfect before i changed the engine, now with the new engine it hangs the 1-2 shift, i have installed different tunes and still fighting the issue for 7 mo., maybe its in my tcm??:confused:
5,920
Welp, my tcm fixed it. Went out and made pass after pass on the highway side roads to get her to learn and it shifts B-E-AUTIFULLY!!! Im so damn happy for this mf'er! No logs though, brian forgot his laptop and mine wont log the tcm for some reason
15,681
Download your TCM OS and then load it into Brians.
