oil. It can't drain and needs to be pumped back up to the engine. Dirt. you can't just slap an air filter on the turbo and go, there is a TON of dirt kicking around under there, even on the interstate. Water. You'll have to plumb the intake up someplace, and there really isn't a good spot to take it that won't make the suction side of things way too long. Heat. Turbos like it, and you loose most of it by the time the exhaust gets there. This can be worked around by sizing the turbine correctly, however you're still loosing alot of useable energy there, and hence having to further choke the exhaust to get it back. Just my take, in the end the choice is yours. If you do this be sure to take pics! :thumb:
With the way my setup is, everything can be removed without lifting the cab one fraction of a inch. Also keep in mind the material I am using is much larger and thicker than normal SS stuff so if that is what you were going to use, going behind the motor and keeping the top of your engine clear would still work. I just love the look of the engine bay being open and cleaned up with hardly any pipes showing face. I also like the whole "short and to the point" method AJ used when building these.
rather then doing the Banks Big Hoss intake. could you do one that is just 1 large tube that goings into the intake? not sure if anyone will understand me... just thought then you could have a 3in pipe coming right from the IC and it wouldnt be very long...
Wow mr negative in the corner over here:rofl:
all these things can easily be taken care of. The only thing I don't like is pending the lenght of the exaust piping but that ain't bad
you could put it inthe bed and run seperate oil systym run the intercooler in the bed even.... Tons of possibilitys! Keep a open mind and wallet
or u could just cut and paste
Really? define remote its not in the factory spot there for some will take it as remote you think way to hard on things Mike an the factory didn't intend on s480 being Were an ihi was before :thumb: its all in ones opinion or perspective
Ever wonder why the flow was reversed on the cylinder head design of the light duramax? Exhaust flow into the valley insted of down and around the engine? So the turbo can be mounted as close to the exhaust port as possible. If I over-think things Jake, then what is it that you do?
I am having a hard time following what your point is or where you were going with this? Basically, what is your point?
Turbos like heat. the further you remove the turbo from heat the worse it is going to perform. The more you tighten the turbine housing to negate the loss of heat the more you are going to force drive pressure up. But what do I know, I'm just an "over thinker".
For more in depth explanation, read the book by Corkey Bell.
