Racing Thermostats:
5,918
I see 165-170*. Gained ~8-10psi of oil pressure everywhere which tells me it's staying cooler.
Brian, that's invalid info. You have a rebuilt motor with new bearings in there. You can't actually say just thermostats alone increased your oil pressure. You have too many other things changed to say that's viable
S Phinney
4,008
Quncy, Fl
I have no problems with the racing thermostats. Drives fine. It does heat up much quicker under wot. Could be thermostats could be block fill but probably both. It cools off within a few seconds as well. No negative comments. Do not expect any miracle experiences when using them. It one step along the way to help g the engine produce. Its probably not going to measure a statistic to justify buying them if that us what you guys are looking for as answers. I like mine but then I did not have a problem with stock ones either.
gmduramax
Shits broke
Jun 12, 2008
4,081
252
Nor cal
I saw an increase of 10-15psi with these in mine and my dads truck.
Mikey
Drag Racer
Jun 13, 2009
560
3
Kat, Can you PM me please. I would like the thermostats. Do you supply both thermostats?
Thank You!
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Thank You!
Yes, But if you PM me with your address I can give you an exact price with the shipping.
Thanks
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Kinda thinking outloud here.
But shouldn't these help lower the trans temps 5ish degrees as well once the truck is warmed up, due to the cooler in the radiator?
5,918
Should also take longer for the trans to warm up as well
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
I think I have replied to all the PM's. Let me know if I missed anyone.
Thanks
:witch:
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Installed these the other day, I don't have an oil temp gauge on my engine but i'm seeing coolant temps around 168-172F and oil psi at idle is up probably 2-4psi.
So far I'm happy, especially with how easy they are to change out.
