pop goes lmm
ripmf666
15,123
14
47
Wentzville Mo
I was just thinking it was going to make it alittle harder for you,It is fun to reset that darn spring.I like the LB7 better.Are you borrowing a oil primer from a dealer when your ready to prime it?
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
i might borrow one. i gotta return the front and rear crank seal installers in the morning at the dealership. mabye ill see if i could borrow his primer. if not, ill piece one together
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
Dammit I wish I would have had Guy paint my block!!!!!!!!!! Way upset about that :mad:
Yours looks great!
want me to tell you what your motor looks like? or you wanna supprise?:D
here are some pics of what i got done today. the machine shop got my heads resurfaced in an hour and a half. done by 11:D they took 3 thousandths off
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
motor is ready to go in with the exception of new flywheel bolts and balancer bolt. then comes the birds nest of wiring harnesses...
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Coool. You know the proper break-in technique is to back out on the street and lay down about 100 yards of track right ..... :D ..... Bounce it off the limiter a few times, make sure it see's a nice variation of rpm..... :rofl:
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
56
Tampa, FloriDUH
not far from the truth!...here is a REALLY good read on breaking in an engine.
http://mototuneusa.com/break_in_secrets.htm
is that the EGR crapola pipe still on that up pipe? if so,man i would have cut that biootch off abd weled a plate over it of some sort myself! but other-wise, looking very good man!
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Are you gonna use the same oil cooler?
iirc the rubber ring is not re-usable and the dealer doesn't sell it either.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
ITS RUNS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:happy2::happy2::happy2::happy2::D:D:D:cool2::cool2::happy2:
i had to put a new ecm in it cuz i fried my last one. i have injector codes saying calibration is wrong. is there a way with efi to program the injector codes and serial numbers and stuff into my ecm with efi or is that a dealer thing? what about a snapon scanner??
thanks!!!
IM SOOOOOOO HAPPPYYYY :happy2:
ripmf666
15,123
14
47
Wentzville Mo
Congrats on getting it running, Not sure about the injector codes, Did you install bigger injectors? when I did the 30% I never got anything telling me to program them,But a tech 2 will be needed i'm sure.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
stock sticks. looked it up. the injector numbers on the top of the injector need to be input into the ecm. im just going to turn the codes off with efi. they are all in the same cylinder i took them out of. i guess the computer just wants the info. dunno why
