Interesting little fact:
These pistons have ~15% less surface area than the stock pistons and ~9% less than typical delipped pistons. If the BTUs of heat absorbed by a piston is directly proportional to the surface area, (it is if the chamber temp is the same) these will run cooler than stock.
This will be good to see results ill be doing a motor this fall hopefully an will use these if they work how we all hope they do
