Over 10,000 miles on my set of pistons now. No issues. My transmission, however, is not so happy.
Something that was bothering me about the FEA was that it showed these, and the stock and the others piston designs failing at lower pressures than I have seen and measured in the real world. I couldn't understand how they were surviving at all. So I used the analysis tool just as a comparative widget so I could see what was better.
Then I stumbled on the issue in my analysis. I was not applying the pressure to the area on the outside of the piston above the fire ring. This turns out to be critical to the piston's strength assessment and, I think, piston longevity in the real world.
Cutting to the chase, this means the pressure differential between the center of the piston and space between the piston head and cylinder wall is THE factor that kills the pistons mechanically. That differential happens when the ignition event is very fast such that pressure does not have a chance to equalize between the center of the piston and the cylinder wall area or when the path is restrictive, like at top dead center when all that quench area is in the way.
