somebody's gonna' be sloweroke:
he was always slow:rofl:
i am just messin with you travis:hug:
it just happened to be that that LLY was stripped to nothing and he was fully loaded plus a 4 inch lift. but lets talk about that LB7 that weighed 7600 -7800 lbs being faster than both of you:rofl:
think about what you are doing, you raise the front end of the truck up. you change the spindles which lets you flip your tie rod ends over. so your steering is straight same as when you let the torsion bars down, all your cv angles are straight across now. and you can crank the torsion bars up which puts pressure on the lower control arm which pushes down on the tire and gives the front axle traction. look at alot of the good running duramax trucks, they are lifted and pull great!hmmm any idea why it pulls better??
Weight is what pushes the tires down, not the torsion bars. The only way a lift would make the front tires have more weight on them is if it somehow changed the way weight transfers.think about what you are doing, you raise the front end of the truck up. you change the spindles which lets you flip your tie rod ends over. so your steering is straight same as when you let the torsion bars down, all your cv angles are straight across now. and you can crank the torsion bars up which puts pressure on the lower control arm which pushes down on the tire and gives the front axle traction. look at alot of the good running duramax trucks, they are lifted and pull great!
I've never really looked at the front angles on a 4" Tough Country lift (or really any lift for that matter). Obviously if you try to have the same height on a stock suspension as you would with a lift, the angles on the lifted truck would be better, but how are the angles any different than a stock suspension truck with the torsion bars lowered?The entire truck just feels like it's into the track better & the obvious is better angles & esier on parts...if that makes sense
