Is this not what I said way early or am I not reading this correctly?
Yeah, but you guys just pull in sand, so you dont know anything :rofl: JK
was that the last pull in london this year?
Let's throw a wrench in it all and ask about my setup:
Stock front end with torsions let all the way down and hanging weight. Rear lowered with drop shackles and bump stops extended so it is resting on them while sitting (unless that pulls rules require 1" travel). Custom hitch directly between the frame rails with the receiver behind the license plate and rollpan - pulling ring sits in line with the shank and at 26".
I only got to hook with that setup twice last year and both times it blew an intercooler boot apart at the end of the track. I had some mix matched used 285-75 BFG and Trxus Mud terrains on the truck on stock rims with 2" spacers in the rear. The front only lifted until it was leveled but the truck wasn't lacking traction. I took 2nd to Ed Wayne by 6 feet on the second pull only because the intercooler boot blew. For this year I've added QA1's that I'll be turning the rebound all the way up on - and if I can may get some better tires.
On Winston's truck we always ran the torsion bars all the way down and his hook very well too. I think getting the hitch in line with the frame rails and as close to the back of the truck helps a good bit too.
Just goes to show that each truck is different.
When the train was here we tried a bunch of different things back & forth between . some worked others didn't. Some worked well on the train & my truck hated them.
I think the lower the bars deals is to save the tie rods & CV's for most. Some will tweak even more :thumb:
I was starting to think I was the only one that thinks that way. I built mine as high as I could to be at 26" which made my loop perfectly even with the top of the receiver tube and as far up under the truck as I could and still be legal. My thoughts have always been that the hitches that come out and do a 90* up 6 or 8in. then pull from above the receiver tube transfers way to much weight to the back way to fast because they are trying to lift the front end anytime they have tension on them. I also see a lot of them that hang so far out behind the truck that it has to be killing the mechanical advantage severely which is just as bad. To me it seems anyone that could get the mount point up enough to do a 90* down to the loop and pull from under the receiver should in theory pull the front end down while having the same weight on the hitch and help plant the front shouldn't it?
It wouldn't pull the front tires down, no matter what it is behind the rear axle and using the rear axle as a fulcrum to pick up the front tires. I think that in as close to the back of the truck as possible is the biggest thing to give it less leverage on the truck. With a roll pan you can have the hitch tucked in nice and tight and build a custom hitch between the frame rails so that you aren't going up or down to get from the receiver to the ring.
looks real good man
Im sure you can read books all day long, and get technical with it, if thats what you want to beleive, is books, run your tbars down all the way all the time. If it was all about weight transfer, which i really dont buy, then a stock truck with the bars cranked all the way down, would probably do better, cause most lift kits level trucks up, where a stock one would set a lot lower in the front. If it was all about weight transfer, ifs wouldnt hook up better than a solid axle. I ran my tbars all the way down when i first started too, just like everyone told me, then i started to try stuff different. Books will take you so far, then experience will take you even further.
