Mitch, I watch the views on the listing page. The forum I moderate has 6,500 views and last I checked, this one is over 1,000. So i know people are spectating
I built the dial board and about 10 others and tried to sell them to local racers. Some did and some didn't work. It's been an ongoing battle, but everything always worked on the camaro.
It worked yesterday, but not today. In the video I quickly stripped a shielding wire and shoved it in the ground connector, but I don't think it quite worked (but it may have helped a little). I have an idea what the cause in, and I'm tracking it down. The control switches only logic off of 2 micro-amps, and the modified unit that I already had prepared (and seemed to work better on a second run I didn't record) requires an 11 milliamp signal to control. It's still a work in progress. The coil wires off the digital 7 box run 535V at 135 millijoules, or 135 milliwatts per second, or about 2.5 micro-amps. The coil output to distributor is 45,000 volts at 2 amps. There's no way I can avoid the secondary currents, but I'm hoping by bringing the controller trigger current above the coil primary current, that the induced charges may not be so significant.
Also, painter called this morning and said he doesn't want to repaint the panels. So he stripped them and brought them back [you can see them at the start of the video]. There's 3 painters in the area, 2 of which haven't given us what we wanted. Hopefully the third try will be the charm. The painter pretty much admitted that he'd never done a pearl main coat before, and it was obvious not everything was done at once. The 3rd painter we're going to try knows how to work pearl and welcomed us to put on paint suits and help spray the panels or supervise the spraying to get the finish that dad wants.
http://www.youtube.com/watch?v=thzCgX2uYiQ
