Yeah would also like to see how that works. And how the install went and so on. Lookin to do this to mine just not sure on what cooler and so on to use.
Thats what I thought, but I have the transferflow tank that blocks 99% of the outside air, then my fuel temps would skyrocket
Where you able to change the oil pump in the truck or did you have to pull the motor?I got my truck up and running again finally and with new stock oil pump I don't see under 30-35 psi hot and new gm oil cooler temps haven't been over 210 and I was running it pretty hard. Both my turbos are ball bearing so they do use less oil of course
