my oil temps are less then coolant temps with new oil cooler.
moparkxracer Well-known member Jun 25, 2010 2,309 33 48 Out and about Oct 21, 2014 #221 my oil temps are less then coolant temps with new oil cooler.
SilveradoTwins02 Hopefully twins soon Aug 5, 2014 194 0 0 Hanover PA Oct 22, 2014 #222 moparkxracer said: my oil temps are less then coolant temps with new oil cooler. Click to expand... What oil cooler and adapter are you using?
malibu795 misspeelleerr Apr 28, 2007 8,317 624 113 42 in the buckeye state Oct 22, 2014 #223 What I did for oil temp control... http://www.duramaxdiesels.com/forum/showthread.php?t=49609
moparkxracer Well-known member Jun 25, 2010 2,309 33 48 Out and about Oct 22, 2014 #224 This is the cooler I am using, http://m.summitracing.com/parts/fld-db-30617 The adapter I got off one of the venders on here. It sandwiches between the oil filter. This is what it looks like. SilveradoTwins02 said: What oil cooler and adapter are you using? Click to expand...
moparkxracer Well-known member Jun 25, 2010 2,309 33 48 Out and about Oct 22, 2014 #226 I want to think its from killerB. I'll see if I can find the receipt for it. I know it's been opened up on the inside of it for more flow.
S S Phinney Active member Aug 15, 2008 4,008 18 28 Quncy, Fl Oct 22, 2014 #228 That should be a Mocal brand adapter
