Doesnt the ecm set the cel if it see's to much difference in water temp?
I didn't realize that with the lml.
The lmm is a high flow low pressure pump while the older ones are lower flow but higher pressure right?
the LML pump flows ~15-20% more.
You cant just make a pump "high flow low pressure" or "high pressure low flow". Thats not the way pumps work. Fluid pumps in general dont "produce" "pressure"...Pressure is just a matter of how much the flow is restricted.
if the second turbo is your added heat source causing the problem, then you would need the cooler as close to the return oil from that turbo as possible for max system temp drop. Like the reservoir where it drains.
if you put a cooler just before the turbo, it would cool the oil for about a foot before it is heated right back up by the second turbo and that hot oil will then pass through all of your engine bearings at the high temp. You gain nothing. It would be like putting an intercooler before the turbo.
imo the oil is going in x amount cooler its going to come out of the turbo x amount cooler.
also, if you mount the cooler in the engine bay then you have a small temp differential to allow the cooler to pull heat.
on a dd i would install it at the front of the truck.
what cooler and lube pump did you go with to circulate the oil in your pan on abby? The pan is going to be the best place to draw the oil to cool if that's where the second turbo drains and plus that's where the engine oil pump draws.
i use a 2gpm pump 1/2" in to the cooler and 1/4" line going out. This increases the pressure but slows down how fast it goes thru a small trans cooler with fan.
its mounted on the back of the truck. On a dd this would not be a big enough cooler but for race applications, i can sit in the pits with a bag of ice and a bottle of nos:thumb:
delivered via tapatalk by your forum daddy!!
Does the LMM oil pump flow more/less than the LB7, LLY, LBZ?
The reason I ask is the wierd way the pressure gauge shows the extremely low oil pressure at low RPM's but picks up quickly in mid-top rpms. I was told this is normal but unlike the other models. Maybe this was GM's way of slowing the oil down in the oil cooler to help with temps?? or am I wrong all together?
same. the only difference between the 01-05 pumps and the 06-10 pumps is that the 06-10 pumps had a reverse-thread nut on the pump shaft to keep the nut from backing itself off.
Theoretically yes, but realistically no. And you would still have 90% of the circuit at the higher temp so it would really only benefit the second turbo itself and nothing else.
I agree. That would be the best place for the cooler. Up there there would be no need for a 12v fan on a DD. Only thing is the added restriction/heat to the rest of the stuff already up there. why can't it be simple!!! lol
Normal. All duramax's do that. The oil pressure gauge is actually accurate. If you monitor pressure with a scan tool, you'll see that it shows pretty much what the gauge on the cluster shows.
Its not like the coolant temp gauge that is "buffered" and not really all that accurate. 20psi hot at idle is about the norm. 14psi hot at idle is the minimum allowable spec per GM. And 42psi minimum hot at 1800rpm.
Ben i thought that 01-02s where the only pumps without the reverse thread
Also, you can change at what pressure the "low oil pressure" warning comes on in table B1402. Has anyone increased this up closer to operating pressure to decrease the buffer It is set at 6psi stock
Highest oil temp pre cooler I have seen is 252*, oil pressure fluctuates from 36-55psi at 2100rpm. Investing in a engine oil cooler. :thumb:
You going to build one?
whats the temp after the cooler brian?
