1TRIKHD
Country boy Limo.
Sep 15, 2015
1,692
388
P.N.W
Yep. That picture above is everything installed. PPE manifolds, 2020 oil cooler, and Setrab sandwich adapter. It’s actually great because now when you change the filter the oil can drip straight in the pan instead of the 4wd drive line.. also easier to get to.
I did it with the engine out… I wouldn’t really want to do that job with it still in the truck but it’s doable, you’ll just get wet.
Is the Setrab adapter different from the adapter you get from the dealer?
Sent from my LM-G900 using Tapatalk
JAG91761
58
5
Ontario, California
finally got my oil cooler trying to see pictures of truck similar to my truck mounted behind the bumper. I have 2004 duramax. No body lift just leveling kit.
turbo_bu
199
Central IL
I am working on putting together an LB7 kit for my truck but was wondering if this where guys are getting the Mocal sandwich oil cooler adapter these days?
I tried the old race parts link, but it didn't work anymore.
When ordering the adapter, it lists a 13/16-16 thread as an option. Does this also mean that the new thread sticking out of the base will still be 13/16-16 thread so we can continue to use the same PF2232 oil filter?
Trimox
156
14
Here where I got mine. https://www.batinc.net/#PRODUCTS
Scroll down to oil cooler take-off and sandwich plates. Model SP2TC
You can't order online but all you have to do is call them and they will fix you right up.
Yes the 13/16" is the correct thread for the 01-19 duramax cooler and filter.
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
I’ve got one for sale.. PM me.
DuramaxRamRod
149
17
NH
Put a 2020 cooler on my truck today went fine other than my temp probe leaking. Had to take it off and put the plug back in. Any ideas on how to seal it? O-ring?
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
So for the heater core line you’re talking about the line that runs up to the heater core that can be sealed off by the DHD style delete/reroute ? Once the egr is deleted ? Will be doing this soon myself on my LMM
Just to clarify for those following this thread that don't already know. The coolant pipe on the LMM that taps off the oil cooler adapter to the rear engine cover is the supply to the egr and then to the heater core. Not the return. Yes it can and should be re-routed like other generations, especially for those who no longer have an EGR and live in cold climates who value their heat.
Reactions: rmk800ak
