jkoprowski
Apr 8, 2019
5
3
Sorry if this was answered already, this is a super long thread, but how many long bolts required for the retrofit?
ShopSpecialties
214
Grass Range, Montana
So I am getting close to installing my 17-19 cooler on my LBZ. Since I have a Kennedy lift pump I need to pull the one plug for the oil pressure switch. It has the same 1/2" NPT plug as the LBZ. I see mentions of the plug being metric and was wondering if that was only for the 2020 cooler ?
5,920
It’s only for the 2020 cooler. 17-19 is still npt
Reactions: ShopSpecialties
jkoprowski
Apr 8, 2019
5
3
So update after receiving the sandwich adaptor from Setrab. It indeed will work with the 2020 oil filter (PF26). It is that same diameter as the oil filter o-ring. Also it looks as if the sandwich plate galleys will flow enough for -12. Should work good. I went ahead and ordered the 2020 oil cooler, I let you know when it’s all done.
jkoprowski
Apr 8, 2019
5
3
I finally got around to Installing the 2020 oil cooler on my LMM. It wasn’t as easy as I thought. It’s just a very tight space especially with the 4x4. One thing that never came up is that the LMM’s heater core is connected to the elbow on the oil cooler. I am going to have to plumb a new return into maybe the top radiator hose or something because the 2020 elbow does not account for this. Not really a big deal. I installed the Setrab sandwich plate and the fluidyne cooler with -12 lines. All seems to be working well. I guess time will tell. Now I have I real towing machine! Don’t forget to relocate the grounding strap from the metal heater core line if you do this on a LMM, it was throwing my gauges off a bit without it. Hope this helps
Reactions: rmk800ak
rmk800ak
40
3
Fairbanks AK.
So for the heater core line you’re talking about the line that runs up to the heater core that can be sealed off by the DHD style delete/reroute ? Once the egr is deleted ? Will be doing this soon myself on my LMM
1,953
Moved Chilly's oil pressure problem into its own thread in Engine Building:
Reactions: rmk800ak
Chilly
101
3
Just a little update..
I removed my sandwhich plate, adapter and cooler. Just running the 2020 cooler. Oil temp came up to 195 on my drive home (usually 180 with the aux cooler). I was seeing around 55PSI around 2500RPM.
I will be dumping the 15w-40 for 20w-50
Sandwhich adapter was -12 fittings all the way to the cooler. Took a good look at the sandwhich adapter and thermostat, can’t really see anything wrong. It will be staying off the truck for the time being.
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
So the 2020 cooler will work with PPE manifolds and up pipes? Gonna get one for my LBZ, just wanted to confirm again. Thanks fellas
Sent from my LM-G900 using Tapatalk
Yep. That picture above is everything installed. PPE manifolds, 2020 oil cooler, and Setrab sandwich adapter. It’s actually great because now when you change the filter the oil can drip straight in the pan instead of the 4wd drive line.. also easier to get to.
I did it with the engine out… I wouldn’t really want to do that job with it still in the truck but it’s doable, you’ll just get wet.
Reactions: moparkxracer
